Stupid drilled and slotted rotors!
Old May 5, 2019 | 08:57 AM
pontiacstogo's Avatar
Noticed this on my front rotors today - guessing they are done;
I think I'm just going to replace them with a good quality solid (not drilled or slotted) rotor unless anyone has any other suggestions.
Old May 5, 2019 | 01:26 PM
JakeRobb's Avatar
Super Moderator
Re: Stupid drilled and slotted rotors!
Yep, drilled rotors are prone to stress fracturing, which is illustrated very nicely by your photo. This is the right time to replace them.
You don’t want solid rotors, nor are you likely to find such a thing for your car. What you want are plain, vented rotors. Plain means no slots or drilling; vents are the interior channels, visible from the edges.
Slotted-only is also good, if the vehicle sees extended track use with elevated pad or rotor temps. It accelerates pad wear a bit, but allows hot pads to offgas a little without disrupting the friction surfaces.
Old May 5, 2019 | 01:29 PM
JakeRobb's Avatar
Super Moderator
Here’s a visual on solid vs vented, in case I wasn’t clear.
Old May 5, 2019 | 01:33 PM
Sorry - when I wrote 'solid' I was simply meaning not drilled or slotted - I realize the OEM's were vented.
PO also put drilled and slotted rotors on the rear - I don't see any cracking on those yet, but I plan to replace those as well.
Old May 5, 2019 | 02:44 PM
A real old WS6.com post about cryogenically treating drilled rotors to reduce cracking..... not really a successful approach.
Cryo Treatment
Old May 5, 2019 | 09:47 PM
JakeRobb's Avatar
Super Moderator
The rear brakes on our cars do VERY little of the work. I’d be surprised if you saw them cracking unless they were very old and had seen some track days.
Old May 6, 2019 | 09:21 AM
This car has definitely had it's share of track days, but I do not know if the rotors that are on the car now were fitted during that part of it's life. The PO never raced it, so he may have fitted them purely as an 'appearance' item. I'm going to replace them just to be sure;
Old May 8, 2019 | 07:59 PM
Did ARP studs in new Timken hubs along with new rotors and pads today. I cannot believe how much quieter the car is - I was aware of some drive train noise it seemed to me like it was coming from the rear end. Boy was I wrong.
Next on my list is new rotors and pads for the rear along with ARP studs and a rear end fluid change.
Old May 12, 2019 | 10:23 AM
Just popped a rotor and caliper off of the rear - no way to get the ARP studs to go in without removing the axles. Not a big deal I guess as I plan to change the fluid anyway so I'll just pull the axles and press the studs in. As I mentioned above 95% of the noise I was hearing has been cured by the front bearings - but should I be doing bearings and seals in the rear while I have the axles out? All bearings or just axle bearings? Any opinions or thoughts?
1quickTA
Apr 9, 2007 11:18 PM
Randy1994
11
May 8, 2006 09:28 AM
mook99TA
10
Nov 10, 2005 11:18 PM
Cerwin Vega Fan
Aug 9, 2004 05:10 PM
burnout04
May 11, 2004 03:24 AM
