Strut top nut
Re: Strut top nut
Are you talking about the top nut on the shock shaft that holds the top seat on the spring/shock assembly? You can not access that nut from inside the engine compartment. You have to remove the spring/shock assembly from the car, and use a spring compressor to disassemble it, and reassemble it. On a stock shock, the nut is usually rusted fast to the shaft, and sometimes even to the metal ferrule in the top seat, and has to be cut off.
http://members.aol.com/InjuneerZZ/im...otos/shk02.jpg
http://members.aol.com/InjuneerZZ/im...otos/shk01.jpg
Or did I misunderstand your question?
Re: Strut top nut
yeah a lil misunderstandin but yeah.. that is the nut im talking about.. what i was tryin to say is i think they might be loose i just replaced struts and springs... so i was seein if anyone knew if i could just unbolt it from the top(engine compartment) and be able to pull it down far enough to tighten that top nut on the shaft. thanks
Victor Lamb
Aug 26, 2017 02:52 PM
carguyshu
Jan 22, 2017 11:19 AM
squarehead
Nov 21, 2014 08:02 PM
