Strut changing difficulty scale of 1-10?
Old Mar 13, 2006 | 07:45 PM
KILMERKARZ's Avatar
I am going to change my front struts this coming weekend, how hard is it and what tools will I need to do the job? I am going from stock to bilstien. All tips for doing this are welcome
Old Mar 13, 2006 | 09:07 PM
OBE1 95Z28's Avatar
Re: Strut changing difficulty scale of 1-10?
Always helps to know what year car you have If it's a fourth Gen, here a good write-up:
http://www.houston-f-body.org/tech/shocks/index.htm
Old Mar 13, 2006 | 09:28 PM
nfa's Avatar
nfa
Its not that hard. Before doing my suspension work, the biggest job I did was change the oil
You will need basic ratchet set/wrenches and a spring compressor.
Tips:
-make sure you paint an alignment mark on the assembly prior to decompressing the spring
-it sounds a bit ****, but I like to chase the theads of any nut/bolt that im reusing. replace any that look suspect and use antiseize.
-your upper strut mount maybe rusted. paint it with POR-15 and cover the upper shock bolt with grease so that the nut will be easier to remove in the future
Old Mar 13, 2006 | 10:50 PM
KILMERKARZ's Avatar
Thanx for those tips, I have a 95. I hope nothing is rusted too tight in place.
Old Mar 13, 2006 | 11:53 PM
slomarao's Avatar
I installed koni's today and my upper mounts were rusted. They had to burned off. they cost 112.50 each, I didn't pay that but they retail so beware.
ad356
Apr 22, 2015 08:35 PM
KYWes
Apr 3, 2015 07:59 PM
Magenta_Hearts
Mar 22, 2015 02:44 PM
1996LT1Z28
Jan 14, 2015 08:09 AM
