Streching, Squeaking sound by front passenger tire when car is warm?
Old Jul 13, 2005 | 05:32 PM
buzzsaw's Avatar
Car - 2000 Camaro SS
Ok so this is weird. I have a loud "strech" "squeak" when accelerating from a stop or coming to a stop.
It comes from the front passenger tire area and it comes and goes.
It seems to REALLY happen when the car is warm and the weather is really warm/hot.
Then you can go to the front passenger fender and push up and down on it (right above wheel) and you can really hear it "wrench it, wrench it" (for lack of better words) something really streching.
When the car is cooler. Pushing on it does nothing.
Where to start on this one ?
TIA
Old Jul 15, 2005 | 01:12 PM
buzzsaw's Avatar
Re: Streching, Squeaking sound by front passenger tire when car is warm?
It really happens after the car is driven for a while the streching/squeaking sound starts on all branking and accelorating.
Then if the guy is stopped for a while (10 mins.) or so, the sound is gone.
You can hear it from he inside of the car.
Old Jul 15, 2005 | 01:38 PM
mac_z_28's Avatar
sounds like you got a squirrel problem.
check out www.chevypests.com
Old Jul 15, 2005 | 01:41 PM
buzzsaw's Avatar
Linkie no workie !?
Old Jul 21, 2005 | 08:26 PM
buzzsaw's Avatar
Well, when the car is hot - 20 minutes or more of driving you can hear it.
It is just not stop and starting it is up / downs and even getting out of the car (weight releasing) that it "streches".
The mechanic said drop it off and he will try to find it, but he will never get it "hot" enoungh.
Is is possible it is my springs that when they are really hot are having a problem?
I am lost and no mechanic can help me. If the car sits for 10 minutes after the noise is gone.
TIA
Old Aug 2, 2005 | 02:38 PM
2SS's's Avatar
Wow, I have the same car with the exact same problem! Have you found out any more about this? It's like a creaking noise right? I was going to try lubing the crap out of the suspension, one component at a time with WD-40 to try and pin point the problem. Any one else have this problem or care to give it a shot? Thanks,
Dan
Old Aug 2, 2005 | 02:50 PM
buzzsaw's Avatar
Dan
That's it! A creaking noise. I didn't know what else to call it. I was going to take it in to the local shop but they will never get it hot enough to get it to happen. So, I am not sure what to do. Are you going to lube it underneth? I don't have access to a jack or lift. Please let me know how it goes, and if I take it in I will let you know.
Happened again today after about 10 minutes of driving in hot 90 degree weather.
Old Aug 13, 2006 | 07:16 PM
96Z28SS#1367's Avatar
I have the exact same problem as well, only mine started after my waterpump went south. Coolant from the weep hole hit the belt and slung coolant all over, and I suspect it got on the bushings.
Mine also creaks only after I've driven for about 15-20 minutes.
I had new shocks and springs put on last year, but I only drive it about 25 miles a week. It's almost an official garage queen......
If coolant on the bushings is indeed the problem, what's the fix other than replacement? I didn't see and grease zerks.
1996 Camaro SS
M6
Old Aug 14, 2006 | 10:57 AM
multicar's Avatar
Sounds like the frame bushings for the swaybar. I use a silicon/dielectic grease with some powered graphite mixed in. Kind of a fix it once and forget it repair.
Doug
ModdedNerd
Dec 25, 2014 05:51 PM
Hurin
Dec 13, 2014 07:38 PM
siguy
Nov 27, 2014 10:07 AM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
