stranos front sway bar
Old Sep 14, 2006 | 07:10 PM
lastZ's Avatar
ive done a search and didnt realy find an answer.....i have a 32 mm bmr front sway bar and a 21 mm ILE rear sway....i was looking into getting sams hollow 35 mm front bar.....the question is... is 35 front 21 rear a good set up......i know that sam sells the 35/22 combo..... can i stick with the 21 mm rear bar, and will this set up give me a good handling car?.
Old Sep 15, 2006 | 08:02 AM
Coolformula's Avatar
Re: stranos front sway bar
Yes it will.
See before sam's bar the popluar choices was the 19 or 21 in the rear. Well everybody used to be using the soild 35mm and adding the 21(a lot based how what you like) was the right combo. The front is still bigger its not like stock 30 and 21(dont' like that setup) Sams 22mm hollow is virtually like the solid 21mm in terms of stiffness its just his is light thats why its 1mm to make that up.
So that setup would be fine. And a good balance.
Old Sep 15, 2006 | 12:18 PM
Sam Strano's Avatar
Pretty well said.... Anyone who has a 21mm solid rear--I tell them they have the same stiffness as my 22mm hollow. It's heavier, and because it's bolted to the axle, it's unsprung weight, but balance wise it's fine. The thing is folks often find they can sell a solid 21 for half or more of price difference between just a hollow 35mm front, and the full set. In short, they can use the sale of a solid 21 to get a hollow 22 after selling the old bar.
Again, a solid 21 is fine in terms of stiffness. If you don't want to change, don't change.
And because of the rate of a solid 21 vs. a hollow 22, my front bar is a fine match for either.
Old Sep 15, 2006 | 04:11 PM
lastZ's Avatar
thanks
Old Sep 17, 2006 | 01:49 AM
96SilverRam's Avatar
I've got the Strano 35/22 setup and I like it alot ! I had my front and rears coated performance red (powdercoat).
96SilverRam
Nov 20, 2016 11:19 AM
Alien
Jun 27, 2015 01:13 PM
96SilverRam
May 5, 2015 09:56 PM
BLK1997Z28
May 1, 2015 12:23 PM
8T8IROC
Mar 26, 2015 09:02 PM
