stock springs front, lowering springs rear??
Old Dec 7, 2006 | 07:30 AM
teke184's Avatar
seeing some info on the adjustable perches with the Koni SA shocks. i'm contemplating a different setup with my car.
i don't want to lower it too much, since i have true duals. but using the lower perches on the konis, would lower the front end right about where i want it. this would be with the stock springs up front.
now for the back....
i know i can take the rear isolator out and drop the rear about 1/2". but i'm worried it may still have a "raked" look to it (since the lower perch up front drops it 3/4").
so i was wondering how the handling of the car would be affected if i installed a set of 1" lowering springs in the rear...WITH the isolator in place.
this would give me 3/4" drop front and 1" rear...give or take. how would the stiffer rear spring affect overall handling? oversteer? understeer?
the car isn't really a race car...neither drag, autoX or road race...but it is a spirited street car. i want a good handling car.
as for the rest of the suspension setup...here's the run down:
STB, LCA, PHB, SFC, 32/21mm solid sway bars
Old Dec 8, 2006 | 10:26 PM
ss9c1man's Avatar
If you used a set of prokits you probably would not notice much difference.
I think you would be ok with just deleting the isolator. If there is any rake it wouldnt be much. Besides since the back is fatter than the front it takes a little rake to make it look level.
ModdedNerd
Dec 25, 2014 05:51 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Dec 1, 2014 08:08 AM
thenewkid
Nov 27, 2014 09:41 AM
PaulN64
Aug 8, 2002 05:39 AM
