stock shocks/lowering springs question
Old May 17, 2004 | 07:14 PM
ianwells100's Avatar
ok, so, here we have it, say i use new stock shocks, i know, i know, i'm poor... if the perch is the same as with a stock spring, and now we're using a 1" lower spring, wouldnt there be a gap between the spring and the top perch? do u see what i mean, whats up with this, how is this not a factor/how is it overcome?
thanks
ian
Old May 17, 2004 | 07:18 PM
Xride's Avatar
ok what?
the shock is jsut in a different stat of extention.
DO NOT use the stock shocks with lowering springs, your ride will suck, and only get worse.
Old May 17, 2004 | 10:08 PM
Bud M's Avatar
The only way there will be space between the top of the spring and the upper spring perch is if your car is lighter than air. Otherwise the car will set on the top of the springs. If the spring is shorter than the stock spring, that is what lowers the car's ride height.
oldschool
Feb 9, 2016 09:21 PM
Louey
Pacific
Dec 25, 2014 03:27 AM
Louey
Pacific
Nov 28, 2014 03:46 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
