steering wheel slop
Old Apr 27, 2015 | 09:18 PM
nikko's Avatar
Question steering wheel slop
Hi I can rock my steering wheel up and down especially in the up tilt position. Is this a repairable issue or do I have to replace the whole column? Thanks Richard
Old Apr 27, 2015 | 10:39 PM
Re: steering wheel slop
Did you check the bolts that hold the steering column up against the bottom of the dash?
Old Apr 28, 2015 | 10:05 AM
rngilliland's Avatar
There are four bolts inside the column that come loose. That allows the upper part of the column to move around. Its a common problem. Do a google search for loose GM tilt columns. There are several tutorials on how to fix it. It isn't hard to fix but requires taking the column apart down to the tilt mechanism. You need several specialty tools. If you don't want to get the tools, any repair shop should be able to fix it.
jasonduaine
Jun 4, 2015 09:29 AM
CheckOutMyRoost
May 23, 2015 02:33 PM
Airplanedoc
Feb 1, 2015 07:14 PM
ro2207
Dec 4, 2014 06:18 PM
