steering wheel slop
Re: steering wheel slop
There are four bolts inside the column that come loose. That allows the upper part of the column to move around. Its a common problem. Do a google search for loose GM tilt columns. There are several tutorials on how to fix it. It isn't hard to fix but requires taking the column apart down to the tilt mechanism. You need several specialty tools. If you don't want to get the tools, any repair shop should be able to fix it.
carguyshu
Jan 22, 2017 11:19 AM
jasonduaine
Jun 4, 2015 09:29 AM
ro2207
Dec 4, 2014 06:18 PM
