Steering Linkage Reinstall
Old Feb 3, 2007 | 10:43 PM
METALBEAST's Avatar
I took my steering linkage loose to get my Pacesetter LTs in from the top. Headers went in easily once I jacked up the motor.
I got the headers all buttoned up, but I am having a problem getting the bottom of the steering linkage to go all the way down. Any tips, methods that you are suppose to use to do this. Thanks!
Old Feb 3, 2007 | 11:06 PM
97 LT1formula's Avatar
i used a piece of wood and a hammer to get it back on. just get creative
Old Feb 3, 2007 | 11:17 PM
KillWhitey's Avatar
What he said
Old Feb 3, 2007 | 11:24 PM
METALBEAST's Avatar
Did you have to spread the bottom of it apart? I tried tapping it on with no luck.
Old Feb 3, 2007 | 11:26 PM
Critter's Avatar
there is a bolt that losens i believe.
Old Feb 3, 2007 | 11:31 PM
bt96ss's Avatar
I've had to just put some lube on it and wiggle it on a bit. More often than not with the bolt out it just falls on as long as its lined up. Its getting the shaft back on the steering wheel side that has always been tough for me.
Old Feb 4, 2007 | 07:34 AM
METALBEAST's Avatar
So do you not have to spread it apart to slide it on? Thanks for your help guys. Anyone else?
Old Feb 4, 2007 | 07:41 AM
Stoopalini's Avatar
No, you do not have to spread it apart.
Lube up the center slip joint and slide it closed, making the shaft shorter. Then put the bottom on 1st, making sure it is aligned with the flat part. Then you can tap the slip joint with a hammer to get the top on the steering shaft.
Thomas.
Old Feb 4, 2007 | 08:51 AM
METALBEAST's Avatar
Thomas.
AH, OK that makes sense. Thanks!
Old Feb 4, 2007 | 10:35 AM
KillWhitey's Avatar
Did you get it back on?
Old Feb 5, 2007 | 09:18 AM
METALBEAST's Avatar
Not yet. Did not fool with it yesterday.
KYWes
Jun 14, 2022 06:52 AM
OutlawPerforman
Oct 30, 2017 05:40 PM
autoxr166
Sep 25, 2015 04:21 PM
Daluchman1974
Sep 11, 2015 06:12 AM
rideordie
Sep 7, 2015 08:22 AM
