Steering column ????
Old Feb 24, 2009 | 08:41 PM
BassProCamaro97's Avatar
I have the wheel off and I'm stripping down the wiring to get rid of the things that I will no longer need. My question is what is the ring called a "coil ASM infl restraint" on SHBOX's site, for? Can I remove it? If so how? The Link below shows it and has it labeled as # 3.
To better assist the information I'm replacing steering wheel with a grant unit and won't need the airbag ever again.
http://shbox.com/1/steering_column_exploded.jpg
Thank you
~Jim~
Old Feb 24, 2009 | 08:53 PM
MikeGyver's Avatar
The coil assembly is airbag related, so if you remove it the airbag system will no longer work methinks.
Old Feb 24, 2009 | 09:02 PM
You wouldn't happen to know the best way to get it out of the column would you?
My first attempt was destructive at best.
Thanks for the quick reply.
~Jim~
Old Feb 25, 2009 | 09:09 PM
jraney's Avatar
Jim.
Follow the yellow wire harness from the the coil assembly (also called a clockspring) to the base of the column. there is a connector, just pull it apart and pull the whole assembly up through the top of the column. There is a snap ring that holds the coil in place (#2 in the diagram) that you need to get out in order to remove the assembly. Not a difficult task.
Just remember that the airbag light will stay on with the air bag disconnected. To disable the light. you need to cut the brown wire at the control unit which is under the center console.
Old Feb 25, 2009 | 09:45 PM
Jraney:
Thanks for the info. Not to worried about lights. The whole car is stripped to its most simple form. The car's going back together as a SBC 427 pro street car.
The clip, #2, is whats holding me up. I'll try and get back on that once I've gotten my radiator mounted.
Thanks for the help guys it is very much appreciated.
~Jim~
IndyZman
Oct 22, 2015 02:17 PM
jackpawt883
Sep 10, 2015 08:53 PM
rideordie
Sep 7, 2015 08:22 AM
War Engine
Aug 28, 2015 06:04 AM
Schul365
Aug 25, 2015 05:47 PM
