Stainless Steel Brake line
Old Feb 5, 2006 | 01:16 PM
  #16
Projectz28's Avatar
Moderator
Re: Stainless Steel Brake line
I think you guys are getting off topic a bit. A rubber line has a shelf life or recommended replacement time. So does a teflon lined braided ss line. But the braided line is 10x stronger (just a number not going on proven fact) and has a life expectancy 5 times that of a ruber hose.
If your more comfortable with a rubber line then use it. If you prefer the benifits of a braided SS line then spend the $100 and get them. Either way you car will stop eventually.
if you have oil coming out of a rubber hose, its bad. if you have oil comming out of a SS hose, its bad.
Rubber hoses can collapse and cause a blockage, SS lines do not.
Rubber hoses do not withstand the same temps and pressures that a SS hose does.
You make the call if its worth the $100 to you.
HarleyZ28
Oct 5, 2015 06:23 AM
SpeedJunkee
Apr 23, 2015 09:51 AM
Jlo
Apr 3, 2015 10:32 AM
zxtce
Mar 12, 2015 08:06 PM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
