SS Braided Brake Lines?
Old Jul 15, 2005 | 02:31 PM
Roger'Z28's Avatar
I'm going to be flushing and refilling my brake fluid soon. I was thinking of getting Stainless steel braided brake lines for front and rear. Is it worth the extra expense to do this? Does it make that much difference in brake pedal feel? Thanks!
Old Jul 15, 2005 | 03:20 PM
87DJP2001's Avatar
Re: SS Braided Brake Lines?
Well worth the expense if you still have the stock rubber lines. Also since its a 95 now the time to replace those 10 yr old ones before they go bad. You will notice a difference in brake pedal feel.
Old Jul 15, 2005 | 08:46 PM
stereomandan's Avatar
I recommend ATE TYP 200 brake fluid. I bought mine from www.raceshopper.com I believe
Yes, SS lines help pedal feel a good amount, as well as a good fluid that doesn't absorb a lot of water. The one I recommended is a great fluid.
Dan
Old Jul 15, 2005 | 11:48 PM
96speed's Avatar
A major waste. Stick with stock rubber lines. The stainless won't flex like the stockers and need to be maintained (replaced/inspected) 5x as often.
I've read about enough horror stories about failed stainless lines to stay far, far away. 100 bucks for a pair of lines? No thanks!
Ryan
Jlo
Apr 3, 2015 10:32 AM
87Aerocoupe
Mar 20, 2015 01:23 AM
zxtce
Mar 12, 2015 08:06 PM
Jazsun
Dec 29, 2014 12:14 PM
