Squeeky As Hell
Old Apr 1, 2006 | 09:14 PM
djkyle25's Avatar
Squeeky As Hell
i jsut bought a 96 camaro z28 and i have had it checked out by 2 mechanics who both said that thought the rear end squeeked alot, liek when u just sit in the car, that it was mechanically sound, if this is so, how can i make the damn squeeks go away? or were they feedin me bull****
Old Apr 2, 2006 | 12:55 AM
97FormulaWS-6's Avatar
Re: Squeeky As Hell
If the bushings have been replaced by Poly ones, they probably need to be dis-assembled and lubed; if they haven't been replaced it might be time.
Also might be a loose car, and in need of a set of subframes.
Old Apr 2, 2006 | 04:48 PM
djkyle25's Avatar
Re: Squeeky As Hell
which bushings???
Old Apr 2, 2006 | 08:00 PM
VegasZ's Avatar
Re: Squeeky As Hell
The rear springs squeak on their bottom perches. Just put some grease where the spring sits on the perch and it will go away.
Old Apr 2, 2006 | 09:29 PM
Re: Squeeky As Hell
Lower Control arm, or Panhard Rod
Old Apr 2, 2006 | 09:56 PM
wrd1972's Avatar
Re: Squeeky As Hell
Most likely lower control arm bushings.
Old Apr 4, 2006 | 01:26 PM
TobyZ28's Avatar
Re: Squeeky As Hell
I second the PHB. Take out and relube the bolts up with grease (or replace the bolts from GM if theyre really worn looking, mine were )
Old Apr 5, 2006 | 06:32 PM
pHEnomIC's Avatar
Re: Squeeky As Hell
My rear brakes squeaked like hell. I used wd-40 on the calipers. Where the pad touched the caliper and stuff. Keep it away from the contact surface on the pads and the brakes if possible. I really dont have any squeeaks now.
Formula Steve
Sep 19, 2023 08:31 AM
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
whitehooptie
Jul 12, 2015 06:10 PM
NewsBot
Mar 19, 2015 12:20 PM
