Squeeky brakes how to fix?
Old Nov 18, 2005 | 07:40 PM
Camaro350z28's Avatar
Im having a horrible problem with squeeky brakes and just dont know what to do about it. I did the LS1 brake upgrade in front and have Hawks pads on all 4 corners and powerslot rotors in the front with cheaper duralast rotors in the back (i want to switch)..
Squeeks under braking, sounds like all 4 corners and then also if i turn slighly right while driving they start chripin away but if i turn abck to the left a lil they do not squeek at all? any ideas?
Old Nov 26, 2005 | 12:42 AM
blackztpi's Avatar
Re: Squeeky brakes how to fix?
make sure the pads have slinecers on them. the pads are a fully metalic i believe so they will be more rough on the rotor surface. this usually means more noise. try and heat the brakes up well for a while. don't ride them but go fast 4 or 5 times (60-100mph) in a row and stop rather quickly. simulate some nascar or something fun like that, but sometimes if you wear them in and take a little pad off, it gets better. it sometimes works, but if it doesn't at least you still had fun doing it and you can be impressed with the braking abilities.
May 1, 2015 01:14 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Jazsun
Dec 29, 2014 12:14 PM
MislMan
Jul 19, 2002 11:41 AM
