Squeaky rear
Old Sep 18, 2008 | 01:01 PM
94greenbandit's Avatar
Squeaky rear
So my back right side tends to squeak a lot. I think the shock may be done but am not sure. Bushings are greased, I just think the shock has dried out or something. Anybody have any thoughts
Just went to check it and i pulled up and pushed on that wheel well and it squeaks
Old Sep 18, 2008 | 02:01 PM
n2ceptor's Avatar
Does the vehicle have poly bushings or rubber?? Poly will squeek...
Old Sep 18, 2008 | 02:46 PM
Uh not sure. LCAs are UMI and Panhard is Edelbrock non adj. It only squeaks on one side
Old Sep 18, 2008 | 06:39 PM
n2ceptor's Avatar
UMI comes with Energy Suspension polyurethane bushings.. Might be the problem... I use a white lithum grease on my bushings to help with the noise... Good Luck in finding the squeek...
Old Sep 19, 2008 | 08:22 AM
Yep that is what I use(white Lithium). I added a few squirts last night and seems to have helped. Wonder why that one would dry out faster than the others. Oh well I need new shocks anyways since they are 150k stock. Any ideas on medium good shocks and springs without lowering
Old Oct 15, 2008 | 12:04 AM
Fatdog2's Avatar
Use wd40 on the bottom of the coil spring.Bend the little red tube thing on the can,and saturate the bottom of the coil spring.Hope this helps.
96SilverRam
Nov 20, 2016 11:19 AM
HarleyZ28
Oct 5, 2015 06:23 AM
BLK1997Z28
May 1, 2015 12:23 PM
thenewkid
Apr 12, 2015 07:42 PM
