squeaky brakes
Old May 12, 2004 | 12:08 PM
ARTIC_Z's Avatar
squeaky brakes
i was just wondering what i can do to stop them from squeaking i just changed them and they started doing that. so is there anything i can do to stop them from doing this? thanks.
Old May 12, 2004 | 07:25 PM
thermwood1's Avatar
What kind of pads did you use?
Certain pads are squeaky based on the material that is used. Typically the ones that say produce less dust (ceramic), are noisy.
Old May 12, 2004 | 09:53 PM
ARTIC_Z's Avatar
the front are ceramic but the back arnt and that is what is making the noise. it started making the noise so i checked them and they were bad so i changed tham and they still make noise and it drives mr insane.
Old May 13, 2004 | 10:12 PM
VegasZ's Avatar
Try the VGX pads. They claim that they dont squeak, and they dont. Ive had them on my vert for years after having enough of the squeaky GM pads.
Old May 14, 2004 | 07:25 AM
thermwood1's Avatar
I've been using the Hawk pads, and i don't have any problems with them.
Hey Artic, what kind of pads did you use on the rear?
Old Nov 24, 2004 | 05:35 PM
GoFast908Z's Avatar
Member
Re: squeaky brakes
I have Hawk pads too. (2nd set) and the rears always squeak under light braking (like stop and go), which I do a lot of. Anyone figure this out yet?
Old Nov 25, 2004 | 12:43 AM
wbna0149's Avatar
Re: squeaky brakes
Before you go changing your new pads . Try spraying or painting the back of the pads with with brake anti squeal. Make sure u hit all the contact points.
Old Nov 25, 2004 | 01:33 PM
GoFast908Z's Avatar
Member
Re: squeaky brakes
done that several times.
Old Nov 26, 2004 | 12:15 PM
wbna0149's Avatar
Re: squeaky brakes
Go fast
i believe that is the nature of the Hawk HP pLus pad. It squeals a little.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
