Spring and shock combo ???? (drag oriented)
Old Mar 22, 2007 | 01:41 PM
95firehawk's Avatar
Alright, here is the rundown of what is already on the car:
-KB DD SFC
-J&M LCA Reloc. Brackets
-Hotchkis springs
-KYB AGX struts up front, custom valved DeCarbons in the rear
(the rear shocks were made specifically for a car with a 1" drop)
-Poly sway bar end links
-stock sway bars, k-member, a-arms
I am getting ready to install (hopefully this weekend):
-Strange 12 bolt (4.10's)
-Lakewood LCA
-Jeg's Adj. PHR
-Edelbrock Adj. TA
-Bogart D-10's w/ 27x11.5 Hoosier QTP's out back, Bogart skinnies up front.
-! front sway bar
I am questioning my spring/shock combo now. I know you want a relatively stiff spring out back but does it make much of a difference up front (that's why a lot of people put airbags in the back right?) I would think that it would be the strut that's gonna be more crucial in helping weight transfer but I am unsure. Should I start saving for some QA1's or is the AGX's gonna do the trick? Now that I am slowly converting my car into more of a weekend warrior than a corner carver I don't want to get to the track only to let the only non-new parts set me back. Thanks for any answers.
Old Mar 22, 2007 | 01:49 PM
2000GTP's Avatar
Personally, I do not like the KYB shocks at all. If it were up to me, I would do QA1s on all corners. QA1 springs in the front and either the stock springs or the Eibach drag springs in the rear.
Old Mar 22, 2007 | 01:59 PM
95firehawk's Avatar
Are the Eibachs a "soft" spring in the back? I know if you buy there set you get an airbag in the pass. rear. My question would be that if I already have a stiffer spring in the back why would there be a need to get a softer spring only to use an airbag to stiffen it up? I'm not trying to argue by the way, I am just trying to learn the principals behind a good drag setup.
BLK1997Z28
May 1, 2015 12:23 PM
siguy
Nov 27, 2014 10:07 AM
Victory Racing
Apr 19, 2010 06:08 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
steve10358
Jul 22, 2002 12:33 AM
