sportline install ?'s please
Old Aug 9, 2004 | 12:42 PM
4SFEDZ's Avatar
Talking sportline install ?'s please
i am getting some sportlines in a few days and was wondering if the springs and shocks, struts were hard to put on? the back looks easy but the front im not sure. also do i have to get anything for my suspension geometry?
thanks terry!
Old Aug 9, 2004 | 05:17 PM
Camaro_Maniac63's Avatar
Re: sportline install ?'s please
Rears are very easy, but you will need a spring compressor for the front springs. As for the suspension geometry, you will definitely need to get an alignment done. LCA relocation brackets might not be a bad idea either.
Old Aug 9, 2004 | 06:39 PM
4SFEDZ's Avatar
thanks alot man......................anyone ELSE??????????????????
Old Aug 9, 2004 | 07:08 PM
Black_Z28's Avatar
Get some better brakes while you're at it.
Old Aug 11, 2004 | 02:18 PM
bruecksteve's Avatar
By all means replace your shocks when you do it. I use to have Sportlines on my car and the stock shocks are no where close to being adequate for those springs. The problem with Sportlines is the fact that they are progressive rate springs and are very low to start with. It's very easy to ride the bump stop, especially with a shock that doesn't have a fair amount of compression damping.
Nov 18, 2023 07:21 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
ModdedNerd
Feb 5, 2015 04:37 AM
Dec 1, 2014 08:08 AM
slothgrant
Aug 22, 2002 03:01 PM
