Spohn Problems....
Old Jan 20, 2005 | 04:13 AM
Heatmaker's Avatar
Advanced Member
Spohn Problems....
For those that have the SPohn TQ arm... and Diamond Subframe connectors... where in the h3ll did you find the longer bolts needed to bolt the thing in under the chassy? I can't find this d@mn bolt anywhere... it's getting annoying... is there a place online that sells the 8 grade metric bolt...
Old Jan 20, 2005 | 10:17 AM
Deenasty's Avatar
Re: Spohn Problems....
you should be able to pick them up at any hardware store..If you get the instructions that were provided with the torque arm, it tells you the specs of the bolt needed. Good luck.
Old Jan 20, 2005 | 10:24 AM
1. Suspension problems belong on the "Suspension...." forum, not on LT1 Engine Tech.
2. I don't see this as a "Spohn" problem... he can't be expected to anticipate every possible combination of installs. All you need to do is buy new bolts. Try McMaster-Carr if you can't find them at your local hardware store.
Old Jan 20, 2005 | 05:01 PM
Heatmaker's Avatar
Advanced Member
Woa... easy thurr.... I wasn't bad mouthing or complaining about spohn... this torque arm is awsome and worth every penny... Quality up and down... I"m just asking where I can find the longer bolts for it... like if anyone knew of a place online or something.. because I"ve been every where with the bolt specs in hand...and no one carries the bolt. I've stopped down every store from Napa to Homdepot...with no look... even hitting up local hardwares... just need some direction.
Old Jan 20, 2005 | 07:30 PM
1racerdude's Avatar
Go to a good bolt supplier.
Old Jan 21, 2005 | 12:44 PM
You're the one who typed "Spohn Problems...." for the topic. In fact, the problem is "I can't find bolts...."
And I told you to try McMaster-Carr.... that is a "place online."
Old Jan 22, 2005 | 02:01 AM
SnakeSkinner28's Avatar
Jeez, takin it a little personal aint ya. I mean there is life outside the camaro forum. Wasnt like it was a vulgar post or anything.
Old Jan 22, 2005 | 03:57 AM
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
They're M8 - 1.25 pitch.. Lowe's has them As does Home Depot.
Problem solved
Old Jan 22, 2005 | 09:41 AM
Heatmaker's Avatar
Advanced Member
I'll check again today at a different Hondedepot... thanks man...
Old Jan 22, 2005 | 10:27 AM
Lowes might be a better bet, they usually have a better selection of bolts and such. Been my experience anyway.
Old Jan 30, 2005 | 01:11 AM
TriPinTaZ's Avatar
Spohn has them, you must have forgotten to order them with your parts.............seems like YOUR problem, not a Spohn problem.
+1 for the Spohn stuff, I have LOTS of Spohn parts on my car
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
96SilverRam
May 28, 2015 02:09 AM
DarkKnight
Buyer/Seller Feedback
May 4, 2015 03:32 PM
