So, I picked up some parts this weekend - PICS
Pic #1
Pic #2
Pic #3
Pic #4
Parts include
Spohn Weld sub frame connectors
Spohn Adjustable spherical rod ended panhard bar
Spohn panhard bar mounting kit
Spohn lower control arms adjustable spherical rod ended
Spohn lower control arm relocation brackets
Spohn adjustable torque arm
spohn pro-series rear drag sway bar
Spohn Front sway bar
Hotchkiss sport coil over springs - drops car 1 inch
Tokico adjustable gas shocks
Baer Track front disk brakes - 13 inch rotors, 2 piston calipers
Baer Touring rear disk brakes - 12 inch rotors, single piston calipers
Baer adjustable proportioning valuve
Aeromotive A1000 Fuel pump
It was Christmas for me
Nick
Pic #2
Pic #3
Pic #4
Parts include
Nick
Re: So, I picked up some parts this weekend - PICS
Originally Posted by ChrisS95TA
LOL nice, you won't get all that in till NEXT christmas
g/l with the install
Nick
your going to have to check your relocation lca brackets with your rear pbr caliper before weling in your lca relocation bracket. on my 85 with 9 bolt bg the clocking of the caliper behind and below the rear. the e brake bracket hit the lce bracket big time had to cut a notch in it for clearance. i also had the bear kit it installs nice the spohns stuff i also have but went with not adjustable lca's. just to give you a heads up on that set up before you weld and install everything check fit your brakes, you may want to clock them diffrently.
http://www.thirdgen.org/techbb2/show...th+lca+bracket
Jeff
Jeff
Jeff
Jeff
Thank you so much for that information. I'm sure it will help me very much throughout my project.
U tha man!!
Nick
