slot car racing solid rod end panhard rod
Old Sep 24, 2004 | 12:00 PM
lt4 fd's Avatar
Hey we installed one the other day but Im not sure if its done right.... is the part of the joint that goes around the ball supposed to be centered and not move? MIne right now I can grab the bar and twist it a bit and the joint on the drivers side moves around on the ball but the other side is slanted or atleast not centered on the ball and tight... basically is it supposed to be centered and is there supposed to be any twisting movement, there istn any side to side though.
Old Sep 24, 2004 | 01:28 PM
97FormulaWS-6's Avatar
Re: slot car racing solid rod end panhard rod
If it didn't move, then you'd have a fixed suspension. The joint rotates around the ball, freely in all directions with the mounting fastener stopping the rotating/twisting motion.
But I'm not quite understanding the description of the rest of the question. If it moves side to side (Meaning the same axis as the bolt going through the ball of the joint) then somethings wrong.
Old Sep 24, 2004 | 04:33 PM
lt4 fd's Avatar
no side movement but one side isnt rotating around the ball, Ill go have a look at it
Old Sep 24, 2004 | 04:52 PM
I'm running the QA1 joints on my rear suspension. They are STIFF to move and should be. I'd check to be sure the locking nut is tight, it may have backed off. Mine did for a while until I finally got them tight.
Hurin
Dec 13, 2014 07:38 PM
Skull Leader
Aug 10, 2002 11:01 AM
PaulN64
Aug 8, 2002 05:39 AM
PaulN64
Aug 7, 2002 06:17 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
