SFC Install: Lift or Rack?
Old May 24, 2005 | 02:35 PM
gibbylt1's Avatar
I brought my '97 down to NE Dyno in Worcester, MA. He said he'd install a pair of Hotchkis SFC's I had purchased. I can't weld, so I have to bring it somewhere. I got there, and he only had a four point lift, no drive-on lift. I was under the impression that the car's suspension had to be loaded when installing weld-in SFC's, and thus on a rack. Hotchkis didn't slot the rear holes of the connectors long enough (where the trailering arm bolt goes through) so I have to go back June 4th to finish the job. Before I do that, I wanted to get some opinions. Also, anyone know of a better place to get this done in the Central Mass/Northern RI area? Thanks
Old May 24, 2005 | 03:35 PM
Terran2k's Avatar
Re: SFC Install: Lift or Rack?
when i had my BMRs welded in, it was on a drive on lift. I believe seeing somewhere if the suspension isnt loaded when you weld them on, when you finally put the weight back on the tires it will stress the welds too much.
Old May 24, 2005 | 05:21 PM
taguy001's Avatar
that's correct, you want to have normal load on the tires when they're welded on. If he doesn't have the proper lift don't have him do it.
Old May 24, 2005 | 11:32 PM
2nd_chances's Avatar
Is it a bad idea to do weld ins with no engine+trans in car?
ImNraged
Aug 19, 2018 08:02 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Boss002
Jul 9, 2015 03:33 PM
