SFC 3 point connection worth extra $$$?
Old Dec 25, 2009 | 04:55 AM
alex-z28's Avatar
I got t-tops that's why I am thinking of getting 3 point connection. What do you guys think would it be worth for me to get them over 2 point.
Old Dec 25, 2009 | 08:38 AM
Wild Willy's Avatar
Better triangulation, what weight is added is low, can be tied together either with a real piece of structural steel or even a driveshaft loop- I voted for this with my wallet-
Old Dec 25, 2009 | 08:56 AM
ZDriver96's Avatar
I purchased tubular 2 pt SFC years ago for my T top camaro. I have no t-top leaks in the rain. My mom had a 94 camaro and the T tops started leaking after a couple of years. She did not have SFC. I've had them on my car since 2000 and it keeps the frame tight enough to prevent t top leaks.
But a 3 point support is without a doubt the strongest. Is it needed? I don't know. I've never ridden in a camaro with a 3 pt set up.
SFC's don't help your handling any but will keep the frame tight and parts from breaking/squeaking/leaking.
Old Dec 26, 2009 | 01:02 AM
alex-z28's Avatar
I wanted to get SFC for years but never got around to it. I read how great they are and what a big differance they make, I just know once I do get them I am gonna be mad at myself for not getting them sooner. My t-tops don't leak but I have tons of raddling/squeaking in the car, probably cause my z is a 93. I have finally decided to get them this spring.
Anyway, I am not sure which to get cause one guy told me because I have t-tops the body/frame is weaker and I should go for 3 point, but then other people said that 3 point are over kill unless you do autocross racing (which I don't) so don't spend extra money for something you don't really need.
Old Dec 26, 2009 | 11:00 PM
Bowtie4life's Avatar
I got the 3pt one because I like pushing the car through the turns. The car doesn't know if it's on the street being driven hard or on the track being driven hard, and also thought it's a good place for something else to tie everything in together.
Old Dec 27, 2009 | 07:30 PM
Z-RATED94's Avatar
I have the 3-point and love them. Yeah there's some extra weight to them but the improved handling justified the few extra pounds IMO.
Old Dec 27, 2009 | 11:41 PM
alex-z28's Avatar
OK I decided to get the 3 point connection SFC. Now which one should I get UMI or SLP they are both like same price. Does one fit better then the other?
Old Dec 28, 2009 | 08:29 AM
Wild Willy's Avatar
They are both reputable companies, and I have parts from both. I have good help from UMI's customer service, so I can say that from experience. Haven't had to use SLP's service yet, it may be just as good- dunno
I will say that UMI has other related parts- the driveshaft loops, the torque arm kit that will tie into those SFC-s- I had to get the torque arm mount for modified exhaust to clear my SLP Y-pipe-
Old Dec 28, 2009 | 08:42 PM
blue 79 Z/28's Avatar
i vote for the umi piece, excellent fit and its light!
Old Dec 29, 2009 | 03:43 AM
alex-z28's Avatar
I got driveshaft loop and the torque arm, I don't know how they would tie ito those SFCs. Got any pics?
I think I am gonna go with UMI, and yeah they look lighter then SLP.
Old Dec 29, 2009 | 09:21 AM
Wild Willy's Avatar
The piece that the torque arm relocation kit mounts to is the same piece that the 3-point SFC's are connected by. Pic from UMI websote:
http://www.umiperformance.com/catalo...roducts_id=197
Old Dec 29, 2009 | 09:40 AM
Wild Willy's Avatar
Holy double-post, Batman! Anybody else having problems with the site updating?
Old Dec 29, 2009 | 10:04 AM
Read the "Announcements".....the site is being moved to a new server. Some service interuptions are to be expected.
https://www.camaroz28.com/forums/announcement.php?f=47
Old Dec 29, 2009 | 10:07 AM
Wild Willy's Avatar
Ah, gotcha- didn't realize you were doing it hot-swapping. Kudos- Knew it was coming, just wasn't paying attention to when-
Old Dec 30, 2009 | 05:38 AM
alex-z28's Avatar
My torque arm looks a lot different then the one in that picutre and I don't think I will able to tie it in with the SFCs. I should able to tie the driveshaft to it though.
