Screw ABS
Old Jul 21, 2005 | 07:47 AM
disco192's Avatar
Screw ABS
Is it possible to completely bypass ABS completely and run soley non-ABS brakes on an ABS equipted car (i wanna remove the ABS unit too). I am having all sorts of brake problems and I just want to get all the stuff out of the way to simplify things.
I just want master to caliper pressure. No ABS to get in the way.
Any way to set this up and/or why it would be a bad idea (and dont give me the saftey issue, non-ABS brakes are 11 billion times better than no brakes I have now)?
THX,
Stu
Old Jul 21, 2005 | 08:56 AM
Re: Screw ABS
We have specific forums for specific topics... "ABS" doesn't belong on "LT1 Engine Tech". Please post on correct fourms. Moving to "Chassis......Brakes"
Old Jul 21, 2005 | 09:04 AM
DarkHorse's Avatar
Re: Screw ABS
You need a proportioning valve for the rears and I would recommend a line lock solenoid for the fronts. Bend 1 line from the master to the proportioning valve - into an adapter. Cut your stock rear brake line and reflare it then screw it into the adapter. Same with the fronts.
Hope you understand this.
BTW - ABS unit weighed in at 18lbs
Cruise control I believe was 5lbs.
Old Jul 21, 2005 | 10:44 AM
disco192's Avatar
Re: Screw ABS
I was planning on getting a Wilwood adjustable proportioning valve for the rears. The only issue I have is with the front brakes. Would I need to put a splitter as I have 2 lines for the fronts? Where would I get one of those?
I work at an auto parts warehouse so I can get just about any adapter I need (we carry full Edelman parts including unbent brake lines) so I guess I could piece something together.
I can run the lines straight into the master cylinder right? Which ones go where on the master? I assume front for front tires and rear for rears.
The whole ABS stuff just drives me insane and when the brake place quoted me 2k to fix my brakes I just about crapped my pants.
(btw, sorry for posting in the wrong section... ive been up all day)
Old Jul 21, 2005 | 11:08 AM
383Z4ME's Avatar
Re: Screw ABS
http://www.sjmmanufacturing.com/ has kits for this. Take a look.
Old Jul 21, 2005 | 01:58 PM
disco192's Avatar
Re: Screw ABS
Hey man, thx alot for that link. I just put in an order for their ABS delete + line lock kit just now. $200 for a ready made ABS delete with a wilwood proportioning valve plus a line lock is a hell of a deal. They are really cool guys too. They come highly recomended.
Old Jul 21, 2005 | 04:55 PM
DarkHorse's Avatar
Re: Screw ABS
That's the kit that I just installed on CANTONRACER's car. I'm going the same route but picking the parts up local and piecing it together. Good kit - very well designed.
Old Jul 22, 2005 | 02:06 AM
disco192's Avatar
Re: Screw ABS
I was gonna do the same thing, but i didnt really see the advantages... even price wise. I can get all the parts (minus aftermarket stuff) for cost because I work in an auto parts warehouse and it still didnt seem to save me more than 20 bucks. Edelman carries all kinds of adapters and brake lines, but it would still require buying a brake line bender and various stuff that adds up.
Keep us posted on how it goes.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
TGGodfrey
Aug 17, 2015 08:43 PM
tnmotown
Aug 10, 2015 11:52 PM
