...??? Ripped upper shock mount?
Old Oct 12, 2008 | 11:15 PM
  #16
Here's a pic of all the components used on the stock shock. The large washer in the picture is intended to fit over the top of the shock and protect it. Appears your shocks have a nubby that prevents the washer from sitting flush with the top of the shock. Not clear what function (if any) the washer is providing in your photo. Is it just slipped over the shaft and hanging loose?
Old Oct 13, 2008 | 12:21 AM
  #17
LT1 POWR's Avatar
That nubby is the adjustable portion of the shock.Name:  Picture070.jpg
The washer should spread out the load on the lower section of the upper shock mount. Instead of just riding on the center piece the washer should distribute the load onto the rubber ring around the center shaft.
Is there something else that should be there instead of the washer?
Old Oct 13, 2008 | 10:54 PM
  #18
But the stock shock rides only on the metal ferrule in the upper shock mount. So do my QA1's. No large washer. There is the dust cover on the stock shocks, with the jounce bumper rubber inside it, and that may serve the same function as the large washer. I can't remember if that rides against the lower portion of the shock mount. In any case, the QA1'a have been in there for 11 years with no torn upper mounts.
Old Oct 13, 2008 | 11:38 PM
  #19
LT1 POWR's Avatar
I called Sam today and he confirmed that the large washer needs to be between the bottom of the upper shock mount and the top of the shock to provide some load distribution on the shock mount.
I got everything buttoned up today but didn't get a chance to take her for a spirited test drive due to some rain. Hopefully tomorrow I will see if this fixed my "bouncy shocks".
Old Oct 14, 2008 | 08:03 AM
  #20
JohnD's Avatar
When I took mine apart, the rust was so bad on the mount I'm sure they would have given out in a few more years. I wire brushed and used rust killing paint before I put them back together. The shock nut was rusted on as well, of course. I had to get some help getting the old one off. We don't have salt to contend with here either, it was just water that had pooled on top of the shock tower from driving in the rain. I noticed that the new (stock) shocks now have stainless hardware so I guess it has been a common problem.
Old Oct 14, 2008 | 04:15 PM
  #21
flyinZ's Avatar
LT1powr-Do you have a part# for that dogbone? I got the rubber mount today at napa, and they didn't have, nor find that "dogbone" part at all...
Any tips with replacing this mount? Im a newbie at struts/front suspension..
Old Oct 14, 2008 | 04:37 PM
  #22
Ricardo's Avatar
You could order from Rock Auto
Monroe P.N. 903933
Spicer P.N. 5201160
Old Oct 14, 2008 | 10:21 PM
  #23
LT1 POWR's Avatar
The technical name for the part is a "Shock Insulator".
The part number for the Moog at Advance was K6573 and it has a limited lifetime warranty for $7.99 each.
Old Oct 15, 2008 | 03:45 PM
  #24
bluz28's Avatar
Yes,you're correct it does.
The factory dust boot assembly which contains the bumpstop has the large washer basically built in (the metal piece the bumpstop fits in ).
Old Oct 19, 2008 | 01:46 AM
  #25
SCNGENNFTHGEN's Avatar
Question
I've seen it before, about a week ago when I had to do my shocks! One of them had ripped right through, exactly like that. My car isn't lowered that I know of either. Now I need lower control arm busings. Are there any stiffer bushing out there for these cars, that don't squeak like hell? Or tubular lower a-arms that won't cost me an arm & a leg?
Old Dec 27, 2008 | 10:45 PM
  #26
carolinacasper's Avatar
Is there anything else needed for the assembly of the shock assembly?
I'm putting my camaro back together and I can't remember if there is another round rubber bushing that fits between the "dogbone" piece and the body of the vehicle.
Old Dec 28, 2008 | 07:59 AM
  #27
flyinZ's Avatar
No, not that I can recall.
Old Dec 28, 2008 | 12:28 PM
  #28
Well I have some pictures here because I really need to know where this extra piece goes...and where I can find a new one because my existing one is covered in rust and dry rot.
1. Here is the piece:
2. Here's how I think it goes back together:
3. It looks like it fits right in there:
4. This is it assembled:
5. And a picture of the forged 355, I'm building. And no, the supercharger is
not going up top, I just wanted it in the picture:
My question is do I have this shock tower assembled right, and where do I get the top piece (rubber piece in picture #1 & 3) above the "dog-bone" piece?
So far these places don't have that rubber piece: Autozone, Advance Auto, and, Summit-Racing.
Old Dec 28, 2008 | 12:50 PM
  #29
bluz28's Avatar
Thumbs up
How about these :
separate L & R piece
Old Dec 28, 2008 | 04:51 PM
  #30
Ah! That's where the piece goes. Thanks, bluz28.
I need another set of them. Anyone know where to get them?
