Replacing rear springs
Old 05-12-2008, 09:15 AM
Camm95Z28's Avatar
Hello all, Soon I will be replacing the rear spring son my 95 Z and have a few questions. Since I am having a mechanic do the unstall, I want to make sure I get all the right parts.
Rear springs and the rubber isolators,I know the rear sway bar gets unbolted, should I get 1le rear sway bar links/bushings or stay with stockers so as to not affect the handling?
Anything I have missed? Thanks for the help.
Camm95Z28 is offline
Old 05-12-2008, 09:52 AM
Rice Killer87's Avatar
Get the Energy Suspension sway bar end links and you'll never have to mess w/ them again.
Rear springs are easy...unbolt the sway bar,unbolt the bottom shock bolts and lower the rear down and they almost fall out.
Rice Killer87 is offline
Old 05-12-2008, 02:12 PM
Z28SORR's Avatar
Don't need a mech! This is definitely DIY stuff. Be careful of the brake flex hose on top of the differential.
Z28SORR is offline
Old 05-12-2008, 03:26 PM
Camm95Z28's Avatar
Thanks, 2 other questions. Does GM still make the rear springs for these cars? Why the Energy Susp. parts abpve the rest?
10-31-2016 11:09 AM
Jazsun
12-29-2014 12:14 PM
ModdedNerd
12-25-2014 05:51 PM
wytblur
03-02-2003 03:40 PM
Quick Reply: Replacing rear springs
