Replacing rear springs
Hello all, Soon I will be replacing the rear spring son my 95 Z and have a few questions. Since I am having a mechanic do the unstall, I want to make sure I get all the right parts.
Rear springs and the rubber isolators,I know the rear sway bar gets unbolted, should I get 1le rear sway bar links/bushings or stay with stockers so as to not affect the handling?
Anything I have missed? Thanks for the help.
Get the Energy Suspension sway bar end links and you'll never have to mess w/ them again.
Rear springs are easy...unbolt the sway bar,unbolt the bottom shock bolts and lower the rear down and they almost fall out.
10-31-2016 11:09 AM
