Replaced Wheel Bearings - Alignment?
I replaced my wheel bearings last week and was wondering if I should have the car re-aligned. It feels like it's fine, but I was just wondering with my pounding the old hubs off if I should have the alignment checked/adjusted.
I believe my car may still be under warranty for alignment.
Shouldn't be necessary. You'd REALLY have to hammer (into a curb!
) your hub to affect the alignment
If the car still feels fine, then you're good. The bearing alone doesn't change the alignment whatsoever
.If the car still feels fine, then you're good. The bearing alone doesn't change the alignment whatsoever
Seriously!!
..... unless he put gobs and gobs of it on, but "assuming" a small enough amount just to act as a barrier against rusting between the hub and the spindle? Probably safe
Hurin
Dec 13, 2014 07:38 PM
