rear wheel stud bad
Old Aug 21, 2010 | 03:31 PM
cleangene's Avatar
rear wheel stud bad
I need to replace a wheel stud on rear, pickup up new ones, popped the wheel off and found the axle has to come out, there's a collar right behind the studs that turns with the axle, will not let them come free, does anyone know if this collar has to be pressed on and off. i will replace all of them if I have to pull the axles.
Old Aug 22, 2010 | 07:05 PM
Do you have traction control? There is a reluctor wheel for the traction control behind the hub. If that's the problem, try a "search" - I believe I've seen posts from people indicating that they figured out how to do it.
Old Aug 23, 2010 | 01:54 PM
cleangene's Avatar
that's it, I figured it had something do with the brake system, thanks I'll do a search and see what I can fine.
Old Aug 29, 2010 | 05:16 PM
cleangene's Avatar
yes I found the thread, and yes it has to do with the traction control like I figured and the axles have to come out, thanks for the information, next question do the rings have to be pressed on/off. anyone know.
HectorM52
Jul 30, 2017 11:46 AM
dpw21562
Jan 23, 2015 04:58 PM
blac94Z
Nov 24, 2014 07:12 PM
squarehead
Nov 21, 2014 08:02 PM
