Rear springs squeek even after putting fuel line over the top of the coils
Old Oct 29, 2009 | 11:45 AM
Mikes 1994 z28's Avatar
Im having a hard time eliminating the squeeking noise the rear springs (eibach pro's) make. Standing in front of the rear fender and pushing the car back and forth for makes the sound. Likewise going over any rough pavement also makes the springs squeek. Im running out of ideas on how to eliminate the noise. I even greased the tops of the mounts hopeing that would help. Maybe its time to replace the rubber piece?
Old Oct 29, 2009 | 02:07 PM
Z-RATED94's Avatar
I just took the isolator out last month and used a piece of heater hose around 3/4 of the top coil and no noise with my Eibachs. Are you sure it isn't coming from some where else?
Old Oct 29, 2009 | 03:23 PM
Im pretty sure. I put my ear right next to the wheel well and shock the car and its coming from above the tire so I think its the spring. Also I didn't start doing this until I installed the springs. Im not ruling out that its no a bushing. Im going to drop the rear end again this weekend and look into it more.
Old Oct 30, 2009 | 10:20 AM
9T8W66's Avatar
I had a squeak after my Strano install, turned out I needed to lube the rear swaybar bushings.
Jazsun
Dec 29, 2014 12:14 PM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
wytblur
Mar 2, 2003 03:40 PM
