Rear LT1 to LS1 brakes?? Help!!!!
Old May 3, 2007 | 08:46 PM
krisb410's Avatar
OK here is the deal, I have a 91 RS with an open/drum rear. I got a LT1 posi/disk rear but no rotors or calipers. So I found brand new LS1 rear calipers and rotors cheaper than what I can get the LT1s for.
So far I have
91-92 1LE prop valve
LS1 master cylinder
LT1 posi/disk rear
LS1 caliper, rotors, and flex lines
Anyways, I think I have the conversion from drum to disk covered, but not the hard lines that run along the axle tube. Will the LT1 lines work or do I need to find LS1 hard lines?
BTW, I 'm doing this so I can put my ZR1 rims on, I got 2 1/4" spacers/adapters for the fronts
Old May 3, 2007 | 08:48 PM
91Z-28's Avatar
You need the LS1 hard lines, backing plates, and axles.
Old May 4, 2007 | 11:29 AM
krisb410's Avatar
Axles????? Really, whats the difference in the axles?
Old May 4, 2007 | 04:30 PM
Slightly different length would be the biggest thing.
ddr698
Jan 9, 2015 10:05 AM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
vals95z
Mar 18, 2003 03:45 PM
