Rear end noise
Old Sep 5, 2010 | 08:53 PM
Brdar II's Avatar
Rear end noise
Hello, I've been experiencing some noise from my driver's side rear wheel in my '94 Z28 convert., basically a squeak that gets louder and faster as I drive, have had several people look at the brakes, to which they said they are fine, and a few other people ruled out the noise as being a bad wheel bearing since it is not a howling sound. What should I look at next? Thanks.
Old Sep 6, 2010 | 04:28 PM
wbacall's Avatar
Look at the brake pad shims. I have had them migrate & start rubbing against the rotor. You won't see it unless you look for it.
Old Sep 6, 2010 | 10:39 PM
chevyz4life's Avatar
check your driveshaft u-joints.
Old Sep 10, 2010 | 05:06 PM
Brdar II's Avatar
Thank you both for your help!
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
