rear Control arm bushings
Old Mar 30, 2005 | 12:02 PM
Bow94z's Avatar
well i bought prothane bushings for my rear control arms. (lower) are they hard to replace? or is it simple just unbolt them off the car and replace bushings then re-install control arm. I hope its nothing like the front control arm bushings.
Cause im using poly...do i need to reuse any parts/casings to get them back in there?
Old Mar 31, 2005 | 09:33 AM
respectirocz's Avatar
Re: rear Control arm bushings
i have not changed the bushings on my 3rd gen but i did change the lower control arms and they came with new poly bushings already in
i can tell u the bolts are a little tricky to get to and to make it easier dont use wd 40, use liquid wrench, 10x better
i believe they are 18 mm bolts, i used a boxed end wrench on one side and let it hold itself against the chassis while i used a breaker bar on the other side, but u have limited clearance so deep sockets and adapters wont help you, just the wrench and the socket, and not everyone has a 1/2 drive 18mm shallow socket
Old Apr 4, 2005 | 09:46 PM
sir dyno's Avatar
Post up the after results with the poly bushing.
I upgraded to poly bushing for my stock torque arm and it made a noticable difference, car felt more stable and seemed more stable while going faster.
Old Apr 4, 2005 | 10:55 PM
Bow94z's Avatar
did it really!!! o i cant wait to put these bushings on along with a panhard rod poly bushings, yea i will let you know withen the next week or so
dbrockma
Feb 16, 2015 02:56 PM
Jason Short
Jan 19, 2015 06:34 PM
thenewkid
Nov 27, 2014 09:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
slothgrant
Aug 22, 2002 03:01 PM
