Rear control arm?
Old Apr 23, 2004 | 08:47 PM
CARdiac's Avatar
Rear control arm?
How do I know when the rear lower control arm bushings are going bad? Squeeking over bumps and a smaking noise over a hard bump (when rear hits)?
How hard are they to replace?
Old Apr 25, 2004 | 12:30 AM
97CamaroZ28R's Avatar
Your LCA bushings are bad. I had the same problem and I went with BMR tubular LCA. They were about $110 if I remember correctly. Replacing the bushings would be about $30. I think it could be done by hammering the old bushing out and hammering the new one in using a piece of wood between it.
Old Apr 26, 2004 | 10:02 AM
mongse_1's Avatar
They're very easy to replace too. Support the chassis with either a lift or a pair of jackstands and put a jack on the rear end. Very easy to remove.
Old Apr 26, 2004 | 10:22 AM
CARdiac's Avatar
Anything I need to be concerned about? Any parts that will be re-used? Any greasing? Any help is appreciated since my manuals don't show didly.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
thenewkid
Nov 27, 2014 09:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
slothgrant
Aug 22, 2002 03:01 PM
