rear camber wear!!
Old Feb 18, 2007 | 06:06 PM
EvilDCustoms's Avatar
rear camber wear!!
ok so i put my car up on the lift the other day to see whats going, any new leaks or anything, and i noticed the tires. The pass rear tire is wearing more on the inner side the the rest of the tire, all the other tires are wearing perfectly fine. What can cause this, i know there is no such thing as camber on the rear tires since its a solid axle. I no i got a bent rim in the back and i think thats it, but would that cause the tire to wear like that, i saw this and was confused?
Old Feb 18, 2007 | 07:43 PM
mook99TA's Avatar
bent rim or under inflated tires can cause it. Start with the known problem. There is no such thing as rear camber on a solid axle.
Old Feb 18, 2007 | 08:31 PM
respectirocz's Avatar
being that the wear is only on the inside of the tire it will be caused by either a bent axle or a bent rim, since u know the rim is bent, fix that first then check the runout to see if the axle is bent
Old Feb 18, 2007 | 09:07 PM
will do, thanks.
PROJECT X
Apr 17, 2015 12:13 AM
sseeya
Apr 9, 2015 06:38 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Collector Car
Jan 5, 2015 10:58 AM
