Rattle Up Front / Shocks & Springs
Old Apr 21, 2006 | 11:49 AM
ut's Avatar
ut
If you have a rattle up front when going over bumps it might be a loose nut on top of the shock/spring assembly. I had my shocks and springs swapped out by a machine shop and after putting back on the car I had a rattle from the front right. I pulled the assembly back off and the nut was indeed loose. Tightened up and now the rattle is gone.
Just a tip for anyone with the problem or anyone who might be replacing their front shocks and springs. Make sure you get that nut tight!
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
siguy
Nov 27, 2014 10:07 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
