QA1 R Shocks and Springs
Old Aug 5, 2005 | 09:41 PM
93ZM6Tally's Avatar
How is this shock on a daily driven vehicle. My car was set up more for road racing with Koni SA shocks on the front and Bilstein shocks in the rear. I have since gotten into Drag Racing. This is still a daily driven car but probably a little extreme - I'll be running a stroker with AFR heads so I should be in the 11's anyways, ran a 12.09 with previous heads/cam stock bottom end. At any rate I'm just wondering if it might be a better choice to go with the other QA1 adjustable shocks. Just be interested in some experienced opinions.
Old Aug 5, 2005 | 10:38 PM
OBE1 95Z28's Avatar
Re: QA1 R Shocks and Springs
I ran the QA1 adjustable shocks on all 4 corners, QA1 drag springs in the front and the handling was poor in the corners and harsh on the bumps. They'll really for drag racing.
Old Aug 6, 2005 | 07:20 AM
93ZM6Tally's Avatar
How harsh and how bad in the corners. I mean did it feel unsafe to drive or did it just not handle as well as a stock Z. I don't mind it being a little "sloppy", but if I have to slow down to five miles an hour for every corner that's another story.
Old Aug 13, 2005 | 09:05 AM
93ZM6Tally's Avatar
I've looked at these shocks and it appears that they don't allow for ride height adjustment like the QA1 OED7855P, it appears that you can only adjust rebound. Comments??
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
KYWes
May 22, 2015 08:48 PM
Charged
Sep 25, 2002 09:28 AM
Pro Stock John
Aug 1, 2002 09:18 AM
