pulls right
Old May 24, 2005 | 07:55 PM
fearnside5's Avatar
pulls right
New struts , strut mounts , shocks and coil springs. Alignment within spec but still pulls right. Tires are also new. Any ideas ? Worn bushings or bearings
Old May 25, 2005 | 09:25 AM
OBE1 95Z28's Avatar
Re: pulls right
Make sure the tire pressure is the same in both front tires. Might also try rotating the tires as see if the problem persists.
Old May 25, 2005 | 06:41 PM
fearnside5's Avatar
Re: pulls right
tried that but, thanks for the input
Old May 25, 2005 | 10:25 PM
OBE1 95Z28's Avatar
Re: pulls right
It took 3 trys for an alignment shop to get mine not to pull and they were using a computer system with lasers. I switched shops the next time and they got it right the first time.
Old May 26, 2005 | 03:40 PM
87DJP2001's Avatar
Re: pulls right
If it pulls right under braking, its the stock rubber brake hoses collapsing under pressure.
2QUIK6
Sep 17, 2016 02:31 PM
jbert55
Oct 31, 2015 03:52 PM
Dams76
Aug 20, 2015 08:28 AM
Cam's maro
Aug 11, 2015 07:45 AM
Z28amustangklr
Jul 18, 2015 11:05 AM
