Problems after Rear Spring/Shock, LCA Install....
Old Jul 4, 2004 | 11:20 AM
  #16
You should have held the rod by the top of it. It fits a ¼" open end wrench, I think. You mentioned something about a gap where the LCAs bolted up. There should not be any gaps where the inner bushing sleeve meets the bracket, after the bolt is tightened.
Old Jul 4, 2004 | 11:45 AM
  #17
Hyperspeed97z28's Avatar
Well after doing the same to the shocks we took off, we figured that out.. Tighted them up, them seem to compress fine and all, the drivers side seems a bit stiffer then the pass side, but they both seem to work fine... I think the little gap where the lca's are is my problem... I've has this same issue with both sets of my PA racing aka pro fab LCA's...
So do you think I could have messed the shocks up?
If the lca's were loose would they make these horrific noises I hear ??
Old Jul 5, 2004 | 08:36 AM
  #18
TTT...
I'll let you know how it goes today, Gonna start on the car again around 10-1030am......
Hopefuly its just the LCA's and all goes well
Old Jul 5, 2004 | 03:52 PM
  #19
It was my LCA's...
All better now !!!
Got my full set of 1LE Springs/Shocks in all around !!!
Couldnt be happier !!
The install went very well...
Thanks for all the advice !@!!
Old Jul 5, 2004 | 06:09 PM
  #20
Brent94Z's Avatar
Super Moderator
Hyperspeed97z28, don't forget a while back we changed the way this forum is used when all the other forums were added. This is for LT1 ENGINE related discussions and no longer for all tech related to the LT1 F-Body cars
I just noticed I've been moving a number of your posts lately so thought I'd just remind ya
Old Jul 5, 2004 | 09:11 PM
  #21
Sorry pal,
I'm still gettin used to the new sections...
jcamaro95lt1
Jan 24, 2015 08:21 AM
siguy
Nov 27, 2014 10:07 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
