Press brakes down "brake" light comes on?
Old May 5, 2009 | 06:08 PM
lilchrisgangsta's Avatar
I start driving my car brakes work fine. If I dont use my brakes for a couple minutes, when I go to press the brakes again the brake goes all the way to the floor and the brake light comes on. But after this happens I pump them twice and they work fine and light goes off? Any ideas?
Old May 5, 2009 | 09:40 PM
n2ceptor's Avatar
Fluid level???? Air in system??? Worn brakes??? If the pedal is going to the floor, there is an issue.... Possibly a worn master cylinder and its bypassing...
Old May 5, 2009 | 10:30 PM
Fluid level is fine, no air in system. brakes are brand new rotors and pads and calipers.
Old May 5, 2009 | 11:29 PM
The "BRAKE" light is telling you that there is uneven hydraulic pressure between the front and rear braking circuits. That could be due to any component from the master cylinder, all the way to the individual caliper pistons. If the pedal goes to the floor, it has to have air in the system, a leak, or the fluid is leaking between the front and rear pistons in the master.
Old May 6, 2009 | 10:01 AM
Bud M's Avatar
Yeah, I've had that happen on some forgotten car years ago. Needed a new master cylinder.
Old May 6, 2009 | 11:56 AM
Thanks Ill look into the master cylinder. Thats probably looking to be the cause of things.
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
!!!TED!!!
Aug 27, 2002 05:41 PM
