Possibly brake squels when turning left
Old Feb 4, 2008 | 03:33 PM
darlandz's Avatar
I have a 95 z28 and i have 89k miles on my car and pretty much whenever i make left turns i hear a loud high pitched squeal. sounds like its coming from the left rear. any way what do you guys think the problem is. and no i havent went and took the tire off to look yet.
Old Feb 4, 2008 | 03:47 PM
flynlow's Avatar
I have the exact same thing happening with my 97Z, hard left turns create a hi pitched squeek. Im also interested in what it is. I was thinking brakes as well but not sure?? Ill keep watching this post too.
Old Feb 4, 2008 | 03:57 PM
briand069's Avatar
https://www.camaroz28.com/forums/sho...r+brake+squeal
This is probably it. Same thing happened to me on my 97. Once I made a thin shim out of a piece of sheet metal and put it on, the noise stopped. Also, if you look at the inside of the rotor you will probably see a wear mark where the caliper bracket is hitting.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CaRParts102
Dec 6, 2014 08:45 AM
formula79
26
Aug 5, 2002 12:21 PM
