Please Help! LS1 brake upgrade question
Old May 9, 2005 | 03:17 AM
onebadponcho's Avatar
Question Please Help! LS1 brake upgrade question
Hello all. Grab a coke or something because this might be long. Anyway, I, like many of us, bought an LS1 brake kit off of ebay (they were actually from a 2000 Firebird). I also went out and bought Hawk HPS brake pads. The rotors that came with the kit were too thin to be machined, so I bought Brembo stock replacement rotors. I've had this stuff for awhile now, and finally got the ambition to put the stuff on yesterday.....only it's not on yet.....
I only was able to start on the driver's side. Here's my problem. I can't get the caliper housing to bolt onto the caliper bracket like it's supposed to. The top bolt goes on all right, it's the bottom one that I'm having problems with; the caliper housing is about 1/4" too far "outboard" from going on. I made sure that the caliper pistons were totally bottomed out prior to attempting installation, and that the rotor was completely flush with the spindle/hub assembly. I haven't even attempted to start on the passenger side in fear that I'll have the same problem. Please help, I'm at a total loss with this; any assistance would be greatly appreciated. TIA.
Old May 9, 2005 | 10:17 AM
Z95m6's Avatar
Re: Please Help! LS1 brake upgrade question
I really don't know what to tell you. I would try rotating the rotor to a different position and then try installing it. Obviously if it slips on then that rotor you bought is trash.
Old May 9, 2005 | 02:25 PM
Yep, tried that and no joy.....would be surprised if the rotor was bad.....would the knuckle being bad cause something like this?....
Old May 9, 2005 | 04:46 PM
slowpoke96z28's Avatar
do lt1 and ls1 cars have the same front spindle and or hub assembly? i would search for pictures of both or call a chevy or pontiac youse and see if they have the same part numbers.
Old May 9, 2005 | 10:19 PM
Bawls's Avatar
Same hub, different knuckles.
Old May 9, 2005 | 10:22 PM
he may need ls1 spindles then, maybe?
Old May 9, 2005 | 10:29 PM
Z95m6's Avatar
Why not try taking the caliper off and seeing if it will slip over the rotor like that. If it does then you must have a bent knuckle.
Old May 17, 2005 | 12:24 AM
Well, I ended up putting my stock stuff back on.....back to the drawing board....
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
