Play in the steering wheel
Old Oct 6, 2004 | 02:38 PM
Agent's Avatar
Whats up guys, I am starting to get a good bit of play in my steering wheel again. Which, is a pain in the *** when I accelerate hard. I think last time I had them changed, it wasn't very long ago. I think maybe I should get some better quality ones than the stock ones then. Any ideas as to if these even exist? Or am I going in the wrong direction, and this isn't even the problem. Thanks!
Old Oct 6, 2004 | 04:41 PM
Red96Lt1's Avatar
Re: Play in the steering wheel
Yeah, it's called a rag joint. It goes in the steering shaft. It is made of reinforced rubber and is designed to help keep vibrations out of the steering wheel from the road. I changed mine out to an aluminum piece. Got mine from unbalanced engineering. It's called a rag joint eliminator. Make sure you have a grinder. I tried everything on a drill, and had to eventually buy one to grind the rivits off. You'll see what I mean when you replace it. It comes with instructions too for around $20.
Old Oct 6, 2004 | 05:06 PM
goin2dc's Avatar
Hey, I have quite a bit of play in my steering as well. When I get under the car, all of the play is in the joint where the steering column enters into the rack and pinion. Is this what you refer to having already replaced once? And is this where the "rag joint" is installed.
Any help would be great. I am planning on replacing the rack and pinion this weekend.
Old Oct 6, 2004 | 09:49 PM
Agent's Avatar
well I looked at where the rag joint is, and its solid. Ever right past it - also solid. I think I have a problem down under the car. I need to get it on a lift this weekend.
Rag joint is under the plastic cover right next to the drivers side header
Old Oct 8, 2004 | 02:32 PM
OBE1 95Z28's Avatar
I've got some steering wheel play too. I have the rag joint eliminator, new front suspension with poly bushings, new ball joints, and tie rod ends, and still have some play. The car steers great but the steering wheel can rotate about a 1/2" with no change in direction. I tried tightening the bearing on the steering rack...no change in play, just stiffer movement of the steering wheel.
Old Oct 8, 2004 | 04:21 PM
vodoo-chile's Avatar
Where's the bearing on the steering rack? Just curios. Thanks,
Kyle
Old Oct 8, 2004 | 05:47 PM
OBE1 95Z28's Avatar
Shoebox's site has everything!
http://shbox.com/1/4th_gen_tech2.html#rack_preload
Old Oct 22, 2004 | 12:39 PM
93redbird's Avatar
But what does this help?
Old Oct 23, 2004 | 10:06 PM
OBE1 95Z28's Avatar
In theory it's supposed to help with steering slop...no help in my case.
Old Dec 3, 2004 | 09:22 AM
OBE1 95Z28's Avatar
Anybody know of other sources for steering slop?
Old Dec 3, 2004 | 11:39 AM
bruecksteve's Avatar
Wheel bearings. Check them with the wheel off the ground.
Old Dec 3, 2004 | 05:47 PM
Camaro_Maniac63's Avatar
Like Steve said, check the bearings. Also, do not let the looks of the rag joint fool you. Mine looked fine from the outside, it felt fine when I yanked on it, but when we took it off just to be sure, it literally disintegrated in my father's hands. I replaced it with a new GM unit, and now I have no play in my steering, it feels great.
Old Dec 5, 2004 | 12:06 PM
OBE1 95Z28's Avatar
Wheel bearings are fine; no play when I push/pull the top/bottom of the wheel. I've got a rag joint eliminator so it's not the rag joint. Completely rebuild front suspension (upper/lower bushings, outer tie rod ends, upper/lower ball joints). I suspect the steering rack as the source of the play.
Victor Lamb
Aug 26, 2017 02:52 PM
nikko
Apr 28, 2015 10:05 AM
Airplanedoc
Feb 1, 2015 07:14 PM
ro2207
Dec 4, 2014 06:18 PM
