Pivoting STB.
Old Mar 3, 2007 | 01:10 PM
LT1 POWR's Avatar
Pivoting STB.
I'm looking at buying a STB next, to help stiffen my suspension. I'd prefer a 3-point design, which limits my choices to Edelbrock, LG motorsports, and Kenny Brown.
Do the pivoting STB's such as Edelbrock and Hotchkis defeat the purpose of a STB or do they still provide strength because the length never changes. I'd prefer a LG motorsports 4-point but I can get a good deal on an Edelbrock 3-point right now.
Old Mar 3, 2007 | 01:55 PM
jaykar's Avatar
Question Stb
Just my personal opinion, but the swivel braces sort of
defeat the purpose of it. Keeps towers from moving in and
out but do not add regidety that I wanted.
I made my own as well as others with my intake in mind.
Am running the MiniRam so was able to go straight across
the engine bay instead of having to arch it.
Two 1 1/2"x 6" plates, 1 1/4 tubing, nice looking gussets
at each end and tig welded. Two 3/8 grade 9 bolts at each
end of the plates and bolts to the top of the towers.
Looks like was a factory option, Shuda been
Going to run a little smaller tubing from tower plates to
cowl area after I make up plate brace under the lip of the
cowl.
JMHO
HTH
later
Old Mar 3, 2007 | 03:21 PM
OBE1 95Z28's Avatar
IMO a STB is only eye candy on a 4th Gen as there is minimal flex in long/short arm setup. The 3rd Gen strut setup benefited from a STB. Lots of posts on this topic, do a SEARCH.
Old Mar 3, 2007 | 04:38 PM
jaykar's Avatar
Stb
I agree as to third and forth gen front suspension not
being the same, but a little bracing and small weight
penalty in a sub frame car can't hurt.
In my car running front coilovers made a noticable
improvement. Alot of cars out there new and old, OEM,
that have run the brace in one form or the other.
In my case running a strong one piece brace between
top strut mounts helps keep alignment specs in hand and
added support for the coilovers.
JMHO
Later
Old Mar 3, 2007 | 10:53 PM
Bud M's Avatar
I always thought of them as hinges. Never made much sense to me.
Apr 16, 2015 09:57 AM
jawzforlife
3rd Gen / L98 Engine Tech
Apr 2, 2004 03:15 PM
jawzforlife
Apr 2, 2004 10:39 AM
Heatmaker
Feb 22, 2004 02:16 PM
385LT1
Mar 12, 2003 06:51 PM
