Parking brake does not work correctly after new pads and cables installed???
Old Oct 12, 2006 | 06:09 PM
95LT1Z28's Avatar
The other day my e-brake cable snapped at the piece that holds the two rear cables together. I replaced the front cable that goes from the hand brake and has the "splitter" on the opposite end and replaced the rear passenger side brake cable that goes from the "splitter" to the rear caliper (driver side rear cable was fine). I also installed a new set of brake pads while I was at it. The brakes are working great, but the e-brake is a different story. I can only pull the e-brake up 2-3 clicks and it is VERY hard to pull up on the e-brake lever. When I get it up 2-3 clicks the e-brake can't even hold the car on a slight incline??? Can anyone give me some insight on what I may need to adjust or what might be wrong? The car is a '96 LT1 Z28, M6. Thanks!
Jeff
Old Oct 16, 2006 | 09:52 AM
OBE1 95Z28's Avatar
Re: Parking brake does not work correctly after new pads and cables installed???
Double check your installation of the e-brake cable. Sounds like something is hanging up.
Collector Car
Jan 5, 2015 10:58 AM
Jazsun
Dec 29, 2014 12:14 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
Jul 4, 2005 05:00 PM
Matt-01-SS
Aug 2, 2002 04:05 PM
