Panhard Bar Bolts
Panhard Bar Bolts
I got a aftermarket panhard bar and it requires 1/2" diameter bolts. The stock panhard bolts are metric and a stepped design. About one half is one diameter( just shy of 9/16" ) then it reduces to just under 1/2". Car brackets are drilled to accept the large diameter on one side only. My concern is if I use 1/2" bolts there will be some play in the one side of the bracket. Just curious if any of you have run into this and how you handled it? Thanks.
carguyshu
Jan 22, 2017 11:19 AM
Trevor98ramair
Jul 31, 2002 02:43 PM
