one side lower
Old Aug 9, 2005 | 06:17 PM
95 WHITE TRANS's Avatar
one side lower
I just installed new oem springs and bilstein HD shocks.My cars left side seems to be lower by half an inch than the right side.(measured at the wheel gaps to about halfway on the tire.)Is this a common problem with f bodys.Car has never been in an accident.But i do place it on jack stands every winter when i store it.
THANKS
NICK
Old Aug 9, 2005 | 07:35 PM
Kataklysm's Avatar
Re: one side lower
Definitly should not be lower, you aren't on a slope/slant of any kind are you? That would be the easier solution, if thats not it try letting the springs break in and see if it changes.
Old Aug 9, 2005 | 09:15 PM
BigEvil's Avatar
Re: one side lower
A lot of F-body owners have this problem, myself included. Most chalk it up to poor engineering.
Old Aug 10, 2005 | 10:37 AM
Re: one side lower
So alot of us are in the same boat.Oh well maybe the 2007- 2008's will be better.
Old Aug 10, 2005 | 10:43 AM
Re: one side lower
No slope/slant actually i tried three diffrent spots.
NICK
Old Aug 10, 2005 | 02:53 PM
OBE1 95Z28's Avatar
Re: one side lower
Could be installation related. Both the front and rear springs mate to a "bushing" that has an orientation to the end of the coil spring. If you didn't line these up properly, it could cause an increase in height.
Old Aug 24, 2005 | 01:43 PM
MarineReconZ28's Avatar
Re: one side lower
My car is lower on the pass. side by about 1 1/4" and I even tried swapping the driver spring to the pass. side and that made no diference.
OBE1 95Z28: How the hell did you join in Dec of 1969???
Old Aug 27, 2005 | 09:08 AM
b55baron's Avatar
Re: one side lower
My right rear was about 5/8" low. I've got the GC weight jackers and used those to even it up.
Old Aug 27, 2005 | 10:18 AM
Re: one side lower
I went to a gm dealer to check the the height of my car .The mechanic said that a half inch off on one side is normal by gm standards.
Old Aug 27, 2005 | 10:47 AM
bunker's Avatar
Re: one side lower
Yeah same here, pass side is like 1.5 inches lower, dont' know why, my rubber bushings are in relation to the end coil last time I checked maybe while putting it in the thing moved, I'll see, might need to modify the rubber thing.
Old Aug 27, 2005 | 12:26 PM
Greed4Speed's Avatar
Re: one side lower
Mine is like that also. Lower in the right rear, but the front is fine. Took out aftermarket springs, went back to stock w/rubber hose instead of isolator and it still sits lower on the right. Wondering if the PHB could be pulling it down. If that doesn't work I'll use the isolator on 1 side and the hose on the other.
What sucks is thats where the exhaust runs over the axel.
Old Aug 27, 2005 | 12:55 PM
RedRyder518's Avatar
Re: one side lower
My car is lower by about an inch on the passenger side. I've heard that they specifically engineered it that way since typically there is only one person in the car, so when the driver sits in the car, it levels out. I notice that whenever I get out of my car, the drivers side raises up by about an inch.
Old Aug 28, 2005 | 08:23 AM
Re: one side lower
Yes i have heard about this too.
Old Aug 28, 2005 | 08:32 PM
Bayer-Z28's Avatar
Re: one side lower
Did you install them correctly?? They are supposed to be orented to a specific corner, I believe. LR, LF, etc.. Just my 0.02....
When I was in techschool, a guy did a set of springs. He installed the wrong spring in the wrong corner and the same happened to his car. Was high on the right side.
Old Aug 30, 2005 | 03:32 PM
Z95m6's Avatar
Re: one side lower
Just a suggestion if your car is off by a reasonable amount on one side just go to your local alignment/suspension shop and get some aluminum spacers. Mine was about an inch lower on the pass. side so i went and bought an aluminum 1 inch spacer that goes over the metal spring perch on the rear and it has a holder made on the other side to hold your spring. Now my car sits about level across the back. If anyone is interested i have one more of these spacers i'll sell for $15 shipped.
MadMav
Feb 6, 2015 11:02 PM
HectorM52
Jan 31, 2015 07:29 PM
Dec 1, 2014 08:08 AM
siguy
Nov 27, 2014 10:07 AM
