Which one for a bigger gain
Re: Which one for a bigger gain
Originally posted by Red96Lt1
Panhard bar, or rear sway bar. I would think the sway bar, but I'm not sure.
Stabilizer bars increase roll stiffness of the suspension. A bigger bar will let the body lean less in a corner, but in the rear of an F-car a big bar is a liability. Our cars basically oversteer at the least touch of the throttle anyway, and a stiffer rear suspension will make that worse. Larger front and rear bars, in a balanced combo, will make the car handle MUCH better, but if its a choice between the two, a bigger front bar will yield much better results. I run a 35mm front bar and finally am satisfied that the car has sufficient low speed roll stiffness.
sway bars, by the way, will not make the car ride harder on the street, in a straight line they add nothing to the spring rates. The worst you might experience is a bit more road "feel" if you put harder bushings and end links on with a bigger bar (again, poly is recommended)
Strano Performance has a great deal on a front/rear bar combo
