No Brake lights
Old Dec 5, 2010 | 09:06 AM
TT350's Avatar
No Brake lights
96 T/A
Ok guys I need a little help.
I have no brake lights except for the third
light in the wing.
The switch is good and all the bulbs in the tail lights
are working.
I tested the tail lights with a Power Probe though the tail light harness under the hatch.
I have emergency flashers and turn signals but no brake lights.
All fuses are good.
Any ideas?
I searched Shoe Box’s site looking for a wiring diagram
of the brake light circuit but didn’t see anything.
Old Dec 5, 2010 | 09:45 AM
Re: No Brake lights
http://shbox.com/1/exterior_lights.htm
The yellow (left) and dark green (right) wires with the "A" and "B" triangles go the the rear brake lights.
Old Dec 5, 2010 | 06:55 PM
95TA04GOAT's Avatar
Re: No Brake lights
While you'll have to go through the the wiring to check for bad connections to be sure, it is likely the turn signal switch.
Old Dec 5, 2010 | 07:42 PM
TT350's Avatar
Re: No Brake lights
Thanks for replying guys.
After trouble scooting with the Power Probe I come to the same conclusion,
it must be the turn signal switch.
Is this common with F-bodys?
I guess I’ll look around on Shoe Box’s site to see if there’s some info on R&R for the
turn signal switch.
Old Dec 6, 2010 | 10:57 AM
RUDEDOG's Avatar
Re: No Brake lights
It's called a multi-function switch. I need one to try and fix an intermittent cruise problem. Let me know if you find one.
Old Dec 6, 2010 | 04:38 PM
TT350's Avatar
Re: No Brake lights
I fixed it about 10min ago, it was the plug coming from the switch on the lower column.
It was my fault, I dropped the column about 2 weeks ago to change some bulbs in the interment cluster
and must have disturbed the plug.
One end was unlatched and pulled apart about ¼ inch.
I plugged it back up and now I have brake lights
The cruse works through the stalk, the stalk snaps into
the turn signal switch and that’s the only relation that they share.
It is listed as a turn signal switch in my 96 T/A
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
